What do you guys use for realistic window glass?
  • What do you guys use for realistic window glass?
    Something that's occurred to me after 7 years of V-ray; I'm still using almost the same method for glass I was when I started.
    What do people do to get realistic, 'PBR' window glass?
    My diffuse is generally black and reflectivity set to about 20% grey (as 255 white is physically inaccurate, if I recall a post by LeLe)
    Is this still best practice?
    I use SigerShaders glass.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Hey Richard7666 what usually works for me is:
      Diffuse : black
      Refl: 245-250
      Gloss: 0.99
      GGX tail off: 1.0 - learned it from Mike
      Hermes tut where he explains that gloss 1.0 is too sharp and values of 0.95 - 0.99 are either way too blurry or slightly too sharp on their own so we counter it with this amount of GGX tail off.
      Refraction: 252
      Refr gloss: 0.99
      IOR: 1.52 - 1.55 depending on the thickness of the glass
      My Artstation
      Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
      Sun Tsu
        From what I recall, Siger's glass is 100% reflectivity which is not physically correct?
          I found all the siger shaders are incorrect actually.
          A.
          www.digitaltwins.be
            no diffuse
            reflect 1.0
            ior 1.5+ as many different coatings make glass unusually reflective
            gloss 1.0 most of the time. in archviz scenes realistic dof and realistic geometry (double/triple glazing) is what makes reflections in glass look good)
            fog is very important. almost always more or less green (iron content in glass)
            max depth for reflection/refraction - high. depends on the scene but in the end this is probably the most important parameter for glass shader.
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
              Originally posted by piotrus3333 View Post
              no diffuse
              reflect 1.0
              I second this. Although the fog multiplier very low at 0.001 and gloss at 1.0 as well, although Lele stated to never use a gloss higher than 0.99, I don't think it looks as good with lower.
              A.
              www.digitaltwins.be
                avoid siger its shaders are bad
                just start with normal values....
                black
                near white reflect
                fresnel ticked
                near white refract
                1.57
                add fog to suit and also surface imperfections in bump and glossiness
                  Oh, it's good enough to be used, not to worry, although there is nothing in nature which is not somewhat rough.
                  It's also super quick, compared to glossy reflections.
                  The one caveat is that it may lead to fireflies, which the slower, but much more accurate glossy calculation process would help alleviate.
                  If one can spare the rendertime, there are ways to make the glossy reflection look closer to a perfectly sharp one (hint: raise the GTR Tail Falloff to something like 10.), but it should be done only if the perfectly sharp one is troublesome.
                  Lele
                  emanuele.lecchi@chaos.com
                  Disclaimer:
                    Damn you Lele your explanation makes me want to change my workflow now
                    A.
                    www.digitaltwins.be
                      unless youre super close, you wont see the difference in 0.99 and 1.0 gloss value. You'd probably also need a bump map to work with the 0.99 gloss to see its effect. Its something Ive worked on for car paint gloss coats alot.
                      Fog colour, the multiplier and the bias help getting tinted coloured glass right.
                      Does anyone use reflect on backside?
                      Website
                      https://mangobeard.com/
                      Behance
                      https://www.behance.net/seandunderdale
                        everybody
                        (I hope)
                        Marcin Piotrowski
                        youtube
                        CGI OCIO config 04
                          There is a second effect which happens with glossy reflections: reflection blurring based on distance of the reflect object.
                          That won't happen with perfectly sharp reflections, as there is no tracing *cone* coming out of the surface.
                          Backside Reflections *needs* fog to work properly and give rise to internal reflections.
                          Notice that performance with glossies *is* appreciably lower with many bounces than it is with sharp reflections.
                          However, in most common cases (read not laser-like lights shining on 1000 bounces of glossy reflections and refractions.) the cutoff routines will prevent the dreaded "rendertime explosion".
                          Mileage will vary, but by no means is the approach unusable, quite the contrary: we suggest doing this precisely because the overall time to job completion is shorter if a render comes out without fireflies (and clumps thereof!) to clean up, besides being closer to reality (as there is no perfect mirror.).
                          Lele
                          Disclaimer:
                            Can you please explain the need for that?
                            • #15
                              Not really, i only recall a convo with Vlado from a long time ago.
                              I've asked again to make sure it's still current.
                              Lele
                              Disclaimer:
