lighting effect
  • lighting effect
    Greetings
    How can I create such a lighting effect (as in the attached image)
    The hidden lighting is only about 10 cm away from the wall.
    Thanks
    put lights in there behind the objects?
    plane lights or a mesh light will work
      Thanks I tried.
      But because of the short distance of light from the wall (10 cm) - there is not enough wide light scattering on the wall
        post the result you are getting.
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          This is just plane lights. Seems to do the trick, no?
            Thanks for the comments.
            fixeighted What distance did you put the lighting from the wall? - It looks good.
            Could you please send me the file?
              After many attempts - that's what came out in the end
                I think the problem is in tonemapping. lights look quite harsh on the wall - should be much softer. or they are just too bright lights to begin with. or actually both.
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
                  Scene attached, though now too late I guess.
                  https://www.dropbox.com/s/oncxd0gpl6...IGHTS.max?dl=0
                    Thanks you all
