vrayproxy with vertex color is lost when UV mapped
  • vrayproxy with vertex color is lost when UV mapped
    Hey fellas,
    we have a problem with an imported asset from houdin in 3dsmax. (basically a cylinder)
    We load an alembic cache (anim) via the VrayProxyLoader and force the first map channel to get a mask (vertex color info CD) on the edges of an object.
    As soon as we use a UVW map or smooth modifier on the vrayproxy - we loose that vertex paint channel info. This also happens when we use compeltely different mapping channels for the applied UVW mod.
    Any ideas for a workarround?
    cheers.
    PS: Emanuele are you listening? ^^
    It seems to be working as expected, the only thing I noticed is that it does not update in IPR and you need to restart the rendering to see the effect (in the scenario I tested). Could you send the specific alembic so we can take a look?
      Hi Aleksandar , thanks for looking into it, Ill send you the file asap.
