How do I create a VRSCENE OBJECT in 3dsmax? (just to IMPORT a VRSCENE)
  • How do I create a VRSCENE OBJECT in 3dsmax? (just to IMPORT a VRSCENE)
    Hello, I am testing the exchange Maya to Max.
    In the documentation is only written
    " Now, over in 3ds Max you can create a VRayScene object to import your file."
    <https://www.chaosgroup.com/blog/how-...n-applications>
    No screenshot, no menu path...
    I looked 15 minutes through everything, I can't find it (I am also not native in 3dsMax)
    Thanks for help
    Right mouse click menu
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      and then...?
      I only can see vrscene exporter.
      And the exporter is for export and there is nothing for import...
      The other items seem not related.
        like this from create panel>Geometry> Vray> Vray Scene
        or simple drag and drop the file into 3Ds Max viewport
        Simply, I love to put pixels together! Sounds easy right : ))
        Sketchbook-1 /Sketchbook-2 / Behance / Facebook
          ok great thanks... I will check out tomorrow
          I simply did not know, that there is more hidden under „objects“
          (like I said, I‘m still learning max...)
            My bad, I thought you were trying to export.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
