big size render
  • big size render
    I'm trying to render a pic 12000*9600 pixels and i get an
    "unknown renderer error(initializing renderer)" when i send it through backburner
    what do i have to do in order to render it at that size?
    btw
    this is an old project in we swiched back to vray 1.09.03.n on max 5.1
    thx
    Gili
    http://www.3dvision.co.il
    First, what in the world are you going to do with an image that size??
    Are you using stripes in backburner? That should solve it.
    sigpic
    J. Scott Smith Visual Designs
    https://jscottsmith.com/
    http://www.linkedin.com/in/jscottsmith
    http://www.facebook.com/jssvisualdesigns
      Hi
      my customers want to print it on 100*150 cm on a printer that does print 200 dpi.
      I can't use stripes because this project is on max 5.1
        Only other thing that comes to mind is doing it manually. Try render regions and select a few (4? 9?) overlapping areas. Just make sure to render to TGA or something with alpha, and stitch them back up in PS.
        FWIW, I used to do plots that size to 200 or 300dpi until I ran an experiment one day and plotted it 100dpi. The difference was barely noticable. Now I never do anything higher than 100dpi if the sheet is bigger than 12"x18" or so.
        sigpic
          there´s a freeware plugin called bigrender from Tomas Cayuela Caudevilla that´s splitting the image in definable buckets, renders these and put´s it together...it´s working with vray
          thomes
          http://web.salleurl.edu/~tomasc/
            What is the maximum size that max render?
            I remember some posts about much larger renders...
              32768 pixel if you have enough memory...but use bigrender...you can render up to 99999 pixel and poster the world...
              thomes
                Hi thomes
                thanks for the script
                Its rendering now (5 of 25)
                Hope it will turn out good , I'll keep you posted
                Do you know which order does it render or is it a puzzle work in ps?
                  hi gilicom
                  i hope you did a test render... i imagine that there is a checkbutton to save every bucket...or the whole frame put together...
                  good luck hope you took the right one
                  thomes
                    yes i did a test render ,it does save them as bmp sequence
                    still renderenig....
                      ouch, why do you use bmp?
                      will be around 300mb in size
                      i'd stick to png/tif for something that large (esp. the lossless compression of png is quite effective on cg images)
                        hi gilicom
                        hope you precalculated the lightsolution first.
                        maybe you get problems with the edges of the buckets...every bucket calculates its own solution...
                        it´s like with backburner, if you stripe a picture without precalculated illuminationmap...every pc calculates its own gi-solution and you get a possible hard edge because of no continuity of the lightsamples...
                        tell me...
                        thomes
                          If you use the vray image type you can render just about any size output
                          check here: http://www.chaoticdimension.com/foru...ray+image+size
                          Eric Boer
                          Dev
                            well
                            Big render script didn't finish the job
                            about vray image type, can't find it under max 5.1 and vray 1.09.03n
                            Does it exist on that version?
                            • #15
                              don't think so, only the newer builds have it
