Upgrading from version 1.09 to 1.46 light problem
  • Upgrading from version 1.09 to 1.46 light problem
    I've recently upgraded to the newest release and now all my models looks very poor. The light is very grey-in-grey and generally the quality has dropped a lot.
    What parameters am I missing - if any? Is there some quick tricks or do I have do rebuild all my old models and adjust 50+ parameters to get my renderings look normal?
    - Jesper
    Ideally you will only need to adjust some render settings; if you can show some images with your problems, it may be useful.
      In the following renders the top series has been rendered with 1.09 and the bottom series with 1.46 - I've made no adjustments at all.
        check to make sure you aren't using max's exposure settings?
          Yeah, it looks like you have left the 3dsmax Exposure on; the 1.09 versions of VRay ignored it, but 1.46 version do take this into account.
            Weeeeeeeeeeeeeeeeeeeeeeeee !
            THANKS A LOT !!! That was exactly the problem. I am a happy man now
            - Jesper
