I'm making some hdri's myself, and I have a big problem.
I put together LDR images with HDR shop. But hdr shop works in gamma 2.2 and vray loads hdri's at gamma 1.0. So every hdri looks too contrasted in max.
Take a look here:
http://hdri.cgtechniques.com/~blochi1/show.php?id=326
That's my problem, and this guy somehow found a solution.
Editing the original LDR images doesn't work. I need to simply render out the hdri set as a background image with gamma set to 2.2 and save this image as my new hdri with gamma 2.2 baked in. But this seems to be impossible! You need the hdri loader from brazil to be able to save to hdri, but when I use the good options for it, the gamma adjustment from max is ignored.
Did anyone else ever found a way to simply edit the gamma of a hdri???
Even better would be if Vlado could add an option to the vrayhdri map to adjust the gamma... please![](https://forums.chaos.com/core/images/smilies/icon_e_smile.gif)
Note that almost every hdri you can find on the net will display incorrect in max as it opens at gamma 1.0.
Take a look here:
