Strange behavior with Vray Clipper
  • Strange behavior with Vray Clipper
    I have a question:
    I used Vray Clipper with a box as mesh and it works fine. That box produces a "hole" in another object ( a sphere).
    I need to make more holes in the sphere just using the same technique, but i can“t copy / instanciate the box ( with the Vray Clipper).
    Operation fails when there are more than one box and one Clipper.
    Is there any way to copy these objects and keep them working fine?
    This seem like a Vray error or limitation.
    Regards!!!
    http://www.mediarender.net
    Hello,
    Yes it is a limitation - you'll have to create new clipper objects.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks!!!
      Best regards
        Or you could array the boxes first, then attach them all...that way you only need one clipper
          Ok thank!!!
          Best Regards
