Refraction anisotropic
  • Refraction anisotropic
    am confronting a case where i need a sphere to be refracted behind a basic refractive plane with a strong refraction glossiness
    but i want the sphere to only be refracted by the z axis
    something like what the anisotropic does with reflection glossiness but in refraction
    can anyone help me achieve this result in any way ?
    i would imagine a horizontal finely striped bump map would work? maybe on the back face if you still require flat reflections.
      unfortunately the result would be very hard to control
        well a procedural map (gradient ramp or similar) on a simple plane, with IPR while setting up is probably not too hard to tweak id have thought..? given there are no anisotropy controls for refraction it seems the only option.
          Yeah i think so it could work
          but an option for that effect would very appreciated
            Click image for larger version  Name:	ANISOTROPIC REFRACTION.JPG Views:	1 Size:	141.5 KB ID:	1071831
            ainisotropic refraction.rar
            that took like 3 mins to set up. uses a bitmap of stripes made from a tiled gradient ramp. i found the procedural map didnt work as expected, but that could be a limitation of the ipr renderer.
            you can control the blur strength with the bump map spinner - it needs some large values.
            max 2018 file attached.
              as mentioned if you need clear reeflections youd probably need to either add a coat material, or use the "bumpy" material on the back face only. have a play!
                that looks amazing !!
                i am trying to achieve it without luck
                and the attached file won't download for some reason
                  if you send me a pm with an email address ill send you the file. for some reason i cant download it either.. some site error.
