Random noise placement that works with Railclone
  • Random noise placement that works with Railclone
    Hello,
    i would like to have a noise texture that is randomly placed on copied objects with railclone.
    Any ideas ?
    I have the impression Vraymultisubtex doesn't work (or new in latest version?)
    Nor a randowuvw map with noise ?
    Thanks
    This is what i try to avoid (the continuous noise texture on the different rectangles)
    Click image for larger version  Name:	noise.jpg Views:	0 Size:	34.1 KB ID:	1079127
      You can probably use a Railclone color and stick 5 or so copies of the noise in there, each with a different offset
      Kind Regards,
      Morne
        reall easy use vray multi sub tex create 5 noise maps and each ones phase make it a bit different
          Or you could try this if you don't mind using UV for Noise
Name:	railclone radnom.jpg
          Simply, I love to put pixels together! Sounds easy right : ))
          Sketchbook-1 /Sketchbook-2 / Behance / Facebook
            Yeah thanks, i tried the Explicit map channel and works well.
