render passes and color mapping
  • render passes and color mapping
    is there a way to get colormapping on my render passes? Im using exponential on an interior and all the passes generated obviously are using linear color mapping.
    Is this the way it should be? Maybe this should be posted in wishlist?
    A work around would be to save to a hdr or exr and do the "color mapping" in post.
    Eric Boer
    Dev
      The passes do not contain color mapping since then it will not be possible to composite them properly. For example, an object with both diffuse and reflection color would look one way in the RGB channel, and different way if the diffuse lighting + reflection were composited in post, if color mapping was applied to each channel separately.
