Black objects
  • Black objects
    Hello,
    I've been working on this stair for work, that we built years ago but can't get any photos.
    Top right, the glazing bars are black.
    Replaced the object, which made no difference.
    Vray 1.46.15 and viz 2005
    Irr + Lc
    Have tried rendering at 3000ish pixels high with high render settings
    tried photon map for secondary.
    Don't think it's a lighting problem!
    Any ideas?
    Geoff
    www.EeDesign.co.uk
    Hey Geoff ..
    are the Bars behind the glass ? .. if so try increasing your global depth.
    Natty
    http://www.rendertime.co.uk
      Maybe their normals are flipped?
        Bars are in front of the glass.
        www.EeDesign.co.uk
          All of the glazing bars are instances, so the normals should all be one way or the other?
          I'm rendering a big one again so I'll post a blow up tomorrow
          Geoff
          www.EeDesign.co.uk
            could it be the reflection cutoff?
            or maybe the glass is coplanar with that edge?
            Eric Boer
            Dev
              If they're instances and you mirrored them, you can get inverted normals. Looking at the image it seems like it could also be coplanar faces
                Hey Vlado ... like your Avatar ..... a little hint there hey ??
                Natty
                  My money is on Dynedain... flipped normals.
                  If you are relying on 2-sided materials - make sure "reflect on backside" is checked.
                  www.studio2a.co
                    There was a nasty little bug with Mirrored Instance's where it turned objects Black ... but that was rectified..
                    Natty
                      Try to play a bit with the SRB ... maybe it solves it
                      Best Regards,
                      Tisho
                        Here's a blow up of that area
                        THink I found the problem. 2 sets of glazing bars. co-planar faces
                        DOH!
                        Odd that it's only done it that area when the whole lot of verticals were duplicated
                        Can't seem to a region or crop render all of a sudden. Why is that?
                        Tishchaos what is SRB?
                        Just rendered left to right reversed. Co-planer faces. So who won the bet?
                        Thanks for all your quick and insightful replies
                        Geoff
                        www.EeDesign.co.uk
                          Geoff, SRB is Secondary Raytrace Bias and is located in the Global Switches rollout - if you increase it to 0.001 it can solve the problems with co-planar faces. But the best solution of course is to just delete them.
                          Best Regards,
                          Tisho
                            It's not black anymore......it's grey!
                            The horizontal bars are the same material and are OK.
                            I'll keep looking into it......
                            www.EeDesign.co.uk
                            • #15
                              Did you try SRB? What happens if you hide everything except the problematic objects? You can send me an email with a stripped-down scene if you like.
                              Best Regards,
                              Tisho
