Convert Standard materials to vray materials, but retain animation on the diffuse slot?
  • Convert Standard materials to vray materials, but retain animation on the diffuse slot?
    Hi All
    I have an export from Synchro which has animated Standard materials which I need to convert to Vray materials and retain the animation keys in the diffuse color slot (see attached).
    I can do this manually by picking the material, create new Vray material, and wiring in the bezier controller to the new vray material but i have thousands so looking for an automated way.
    I've tried a couple of material converters but they don't bring across the animation.
    thanks in advance!
    Neil
    The plugin "V-RayMtl Converter 3" will help you, which you can find at this link: https://maxtools.3dzver.ru/vmc
    The current version 3.996 implements the function of transferring diffuse color animation keys when converting materials (currently support for Standard, Raytrace, Architectural, CoronaMtl, CoronaLightMtl, VrayMtl and VrayLightMtl).
    V-RayMax Converter PRO
    MAXTools
