Can I set different parameters for Production and Iterative rendering mode?
  • Can I set different parameters for Production and Iterative rendering mode?
    I'd like to set different render settings for Production mode then for Iterative. For instance, Production mode I want to set GI to Brute Force, for Iterative to Irradiance map. However, when I set my preferences in Render Setup - Production pull down, and then go to select the Iterative pulldown, it keeps tthe same settings when switching between Production and Iterative pulldown.
    Is it possible to save a setup for both production and iterative that are different from each other?
    Vray 5 and 3ds Max 2021
    I think not, it is a 3ds max functionality (you cannot set it in other render engines as well). However, you can save render presets (Render Settings>Preset>Save/Load preset) and load them whenever required.
      This is sort of for that.
      Try./ It is free.
      https://renderstacks.com/rsprvrender/
      If you want to change GI methods, you can set up with renderStacks.
