Vray 5 - New Frame Buffer Maxscript Access?
  • #16
    I was happy to find a bakeLayersToLUT function in the manager (was done via vfbControl #saveglobalccpreset before).
    How to enable/disable all Display Corrections (eyeball besides Display Correction in the UI)?
    How to enable/disable specific layers (e.g. Background)? I did not find a property for this in the layer manager.
    Daniel
    Daniel Schmidt - Developer of psd-manager
    • #17
      Using the same code as in my previous post:
      Code:
      mgr.displayCorrectionLayer.profile = 0  --this isn't exactly what you asked, but it's equivalent in effect, in that it disables all display corrections
      I've inquired as to the display property itself, which seems indeed missing.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
      • #18
        mgr.displayCorrectionLayer.profile = 0 sets display corrections to None, but it doesn't turn off all color corrections and effects in the layer tree below it as the eyeball switch does in the UI.
        • #19
          ah, indeed.
          Well, the interface to show and hide will be coming in a hotfix soon.
          It only needed to be exposed, and was somehow left behind.
          Will poke you as it's in the nightlies, if you have access.
          Lele
          Disclaimer:
          • #20
            Oh! Finally!!!!!!!
            • #21
              dans we now have the layers' ".enabled" property in the nightlies from today (30651).
              Code:
              mgr.displayCorrectionLayer.enabled = false
              KramSurfer we also have new methods to store and read layersets to and from JSON strings, which you may find useful.
              Code:
              --storing
              myJSONString = (mgr.saveLayersToJSON()) --get the layout in a string
              --reading
              mgr.loadLayersFromJSON myJSONString --reads the layout from a JSON string
              Lele
              Disclaimer:
              • #22
                ^Lele^ is there a way to check if the VFB has any image data loaded?
                I am trying to avoid the error "Image required while saving LUT preset!"
                Set V-Ray class properties en masse with the VMC script
                Follow me for script updates: @ollyspolys
                • #23
                  Code:
                  vrayVFBGetNumChannels()
                  returns 0 if no image is present.
                  Lele
                  Disclaimer:
                  • #24
                    Originally posted by ^Lele^ View Post
                    Code:
                    Perfect thank you!
                    • #25
                      Originally posted by olly View Post
                      Perfect thank you!
                      yavor.rubenov to thank for this one!
                      He is so proactive he messaged me the answer before i knew there was a question (and i ain't joking!).
                      Lele
                      Disclaimer:
                      • #26
                        Well thank you yavor.rubenov - very much appreciated
