Render time
  • Render time
    Hello,
    i have a little question about the new version of VRay (1.47.02):
    The seem file render with the old vesion of VRay (1.09.03r) is much faster then the new version. For the new version, i have just open the max file and render.
    The renders :
    1.09.03r
    1.47.02
    Why ???
    Vince
    (sorry for my english )
    Architecture & design Sàrl
    global solution for architecture
    www.architecture-design.ch
    Well as you can see (I hope) there is a lot more noise in the 1.09 version, basically 1.47 takes more samples at the same settings, you can reduce the settings in 1.47 to better match the time and quality of the 1.09 render.
    Eric Boer
    Dev
      and dont foget that when you just open and render your rendering with QMC samples in the secondary bounce as 50. they should be 8. lower to 8 and im sure there will be quite a difference
        Thanks guys for your fast replays
        I have made many tests but my rendertimes is very long (over 3min)
        The file of my test http://www.architecture-design.ch/vi...strapidite.max
        Thanks for your help
        Vince
          the only noise I can see is that of jpg compression... I don't see a difference between the two versions.
          The new versions are simply slower on simple scenes. Fill that scene with trees and displaced grass, and it will be faster in the new builds.
            Load the images up in PS as layers and switch between them, the difference is quite obvious... The difference mode is too convoluted by the compression to be of any use. Vlado has stated many times that the newer versions take more samples at the same settings as before.
            If I still have a copy of 1.09.03 at home I will try for myself
            Eric Boer
            Dev
              [quote="RErender"]
              Thanks
              It's very kind of you!
              Vince
                Well a little bit slower maybe with a little more tweaking...
                I don't know what your gamma is at so mine are without gamma correction.
                Mostly just played with the QMC, also turning off "multipass" shaved off a few seconds.
                Could probably shave a few more with the GI thresholds but I just
                left it on high. Also a few seconds seem to be wasted while the last bucket
                finishes it's GI calc and the other 3 threads wait to start the final render.
                http://webzoom.freewebs.com/varcht/t...teadjust02.max
                Eric Boer
                Dev
                  maybe this would help to understand...
                  http://www.chaoticdimension.com/foru...in+grain+grain
                  best regards
                  themaxxer
                  Pixelschmiede GmbH
                  www.pixelschmiede.ch
                    best regards
                    themaxxer
                    You do not agree that the noise levels in my tests are very close with only a slight increase in time? 10% instead of 53% ...
                    Eric Boer
                    Dev
                      The only thing I see in both of your tests is that the detail of GI is always better in the 1.09 version. The new build looks very blurred.
                        To me the GI at the bases of the boxes look very similar, please take the time to show me where you see this huge difference.
                        Eric Boer
                        Dev
                          http://users.pandora.be/stor1/vray/compare.htm
                          Mouse over and out of the image.
                          Note that in 1.09 the corners are darker, in the 1.47 version everything gets blurred. (The 1.09 had a coarser jpg compression... don't watch that ugly noise from it)
                            Yes it is a little more apparent here on my monitor at work, still it should be noted that speed increases can be had by adjusted the QMC with little noticeable difference between the 1.47 at 2:11(the unadjusted from 1.09) and the 1.47 at 1:13.
                            Eric Boer
                            Dev
                            • #15
                              Thanks RErender for yours tests
                              Good week-end
                              Vince
