I'm not sure if this is something that already exists, if it can be made to exist through VRay or maybe it is something that 3DS Max needs to work out or if there is a plug-in anyone knows about (and not have to use SceneStates which is painful).
I've run across needing to change the aspect ration depending on the camera angle for some of my renderings. The problem is that I forget I did that, and so I end up rendering and having to re-render that camera angle because I forgot to change the Aspect Ration. Is there a way to change the aspect ration for a camera only, not the whole file? That way I can set each camera with the correct aspect ration independent of the overall file.
Tks!
Tks!
