We do a lot of animation, while we love Corona I've been told that Vray is much faster for animation. I haven't used Vray in quite some time, but tried the Demo version and have some questions before we decide if we will move over to Vray. I must say Vray has come a long way, things are looking really great now. I'm really interested in the Vray GPU also, for speed and local inhouse renderfarm. But of course right now it's impossible to get a videocard, let alone multiple RTX 3090's. So we are running Threadripper 3990x's which are fast.
1) Samples - Trying to compare speed of Corona and Vray. So far my renders are rendering faster in Corona. But I'm sure my settings are not 1 to 1, and I'm messing up the comparison here. In corona you have just "Noise Level Limit" compared to Vray where you have "Noise Threshold" and "Min / Max Subdivs". So trying to get the renderers as close as possible, I thought Vray 0.03 Noise Threshold was equal to Corona Noise Level Limit of 3.0%, but that doesn't seem to be the case. What are good setting to compare each? This will help me because I know what settings I use in Corona for final quality, so to be able to transfer over to Vray will be great.
2) Displacement - In Corona right in the main material we have settings for displacement. You can set the min and max level in actual units, can you do this with Vray? We use this with almost every material, so objects with multi materials like trees can have displacement on just the trunks. How is this accomplished in vray?
3) Albedo - In corona you have a Albedo render element so you can check that the Albedo isn't to high. We purchase a lot of models and can't tell you how many times one of them has a material with to high an Albedo and it makes the render engine take forever. Having that Albedo render element is priceless to checking and fixing the scene quickly.
4) Denoising - I noticed the Vray Denoiser denoises the background HDRI, is there a way to stop it from denoising the background image?
5) Converter - I use the Corona Denoiser constantly, it has great interface and options and converts vray scenes over to corona like 95 - 99% perfect. But the Vray converter doesn't have much options at all and does frankly a pretty terrible job of converting Corona over to Vray. Is there a better way of converting? Is this to be updated?
6) Adjustment - In corona I can set the MSI down from 20 to 4 and the Sampling balance > GI vs AA Balance down from 16 to 8 and get much faster renders. I tried reducing MSI in Vray but it didn't speed up render much if at all. What are setting that would increase speed but still keep quality in Vray?
