Blur GI and light leakage
  • Blur GI and light leakage
    Sorry if this has been discussed previously.
    I am having real difficulty achieving a good interior render without light leaking in through all the corners. After much experimentation, I have isolated the Blur-GI parameter as the culprit. The only way I can find to remove the leakage is to set this parameter to 0. I can't believe this is right as the default animation setting has the blur-gi set to 8.
    Is there another parameter that would allow me to keep the blur gi up at 8 without suffering from this light leakage?
    Thanks in advance for your advice.
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
    do you have any moving objects in your scene?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Maybe a stupid question, but did you try "check sample visiblity?" It may help with your light leaks.
        Re: Blur GI and light leakage
        Nope. Setting Blur GI to more than 0.0 will produce light leaks around thin walls. If you don't want this effect, set it to 0.0 or make the corners with thick walls. The "Blur GI" setting is mostly useful for animations of moving objects, which have small details that may flicker from frame to frame. In all other cases, set it to 0.0.
          Thanks for the feedback everyone!
          So, is the light leakage connected to the scale of my model?
          If I have to reduce blur gi to 0, then I need to bump up the other parameters to smooth out the gi solution. Can you recommend the best way to do this without vastly slowing down render times?
          I am not animating any objects, just the camera.
          I did set "check sample visibility" but it had no beneficial effect.
          Patrick Macdonald
            Set Blur GI to 0.0 and follow the tutorial about Walk-through animations in the Online Help - it offers a useful and fast way to render animations with moving camera.
            Best Regards,
            Tisho
              Thanks, I have used the walk-through tutorial, but I was curious as to why the light leakage wasn't a problem with the model in the tutorial. What is it about my model that causes the problem? Does the model in the tutorial have overlapping surfaces(thick walls) to avoid the leakage?
              Is it prefereable to overlap walls (which leads to a less clean model) or to drop GI blur to 0.0 ?
              I'm just interested to find out what the best workaround to this problem is.
              Thanks again!
              Patrick Macdonald
                In the tutorial, Blur GI was set to 0.0 (we used the High preset), so that's why there are no problems there.
                  OH, I'm sorry! ... I missed that when I scanned through the tutorial again...
                  DOH!
                  Patrick Macdonald
                    Ok. i've been having a bash at the tutorial again and was wondering what settings for the irradience calc would be best.
                    The tut states " 3.2. Make sure the irradiance map Interpolation type is set to Density-based. This will enable the irradiance map to pick the closest available samples from the cached solution."
                    ...but the interpolation type does not have this option (it's under sample lookup" , which interpolation type should I use in conjunction with density-based sample lookup?
                    (I am using v.1.47.03)
                    Patrick Macdonald
                      They are basically all default settings, so the Interpolation is "Least squares fit" and the sample lookup is "Density based".
