possible to get a copy of the dirtmap / ao shader?
  • possible to get a copy of the dirtmap / ao shader?
    Hi Folks,
    Just wondering if it's possible to get the ambient occlusion / dirtmap shader that has been mentioned on here a few times? I need to render a film res job with a quite detailed interior and dirtmap seems a pretty effective way of getting a nice result - it's got a few moving parts in it so the multiframe ir map or light cache won't work as well as I'd hope - Vlado mentioned that it was possible to get the shader in it's current state - is this still possible?
    Also where is the irmap viewer located? I don't seem to have it with vray 1.47.
    Sorry for all of the noob questions - I've been using qmc for everything so far.
    Cheers,
    John
    if this is going begging then I would like to give it a run for the project im doing at the moment too
    cant use MR shader coz im using vray proxies. (i could render a mask pass for them i guess, but its a pain)
    Freelance TD/Generalist
    http://www.vanilla-box.co.uk
      John,
      You can try this AO plugin http://plugins.angstraum.at/ . Marc has written some great plugins. I haven't tried this one yet though. It may be what your after.
      As for the animation Vlado has added a new parameter in the Irradiance Map settings called GI Blur. As I understand it you can use this setting to reduce the flickering affect you get with moving parts.
      IMap viewer is available in the user download area on the docs page.
      Chris.
      Chris Townsend
      Lucid Image
      www.lucidimage.com.au
        The AO plugin mentioned actually is not an AO plugin but uses GI to create a GI pass...just a one-click shortcut.
        The Dirtmap/AO shader is available as source in the sdk, so you´d have to grab theSDK and compile it.
        Greetings,
        Thorsten
          Cheers Unknown but as instinct mentioned, marcs plugin does a skylgiht pass with no bounces whereas I need a true ao plugin that renders a pass for areas where light will trap, like a dirtmap pass.
          Instinct - any idea on how i'd go about compiling it?
            We have a compiled version(of the VRay AO plugin) for VRay 1.46.16 for max 6, 7, and 7.5. If Vlado does not have a problem with it we could send you that build.
            Corey Rubadue
            Director
            Chaos Group
              Thorsten
              this is true, i have just tried it and my scene just bombs. the mr version is true shader based. Would be interested in running the vray version, as its an important function for me and my projects.
                share the wealth
                thats if its ok!
                  "The Dirtmap/AO shader is available as source in the sdk, so you�d have to grab theSDK and compile it.
                  Greetings,
                  Thorsten"
                  So why is this not available to all users through the users download section? Or am I missing something?
                  Thanks,
                  rpc212
                  rpc212
                  "DR or Die!"
                    You have to request the SDK to get it...why the compiled version isnt available ? cause the code is (or at least was when we started working on our own enhancements) far from beeing complete. It was neither optimised nor had a proper UI (at least when compiled with VC)...at least that´s what i´d guess...vlado would have to comment on that one i guess hehe
                    Thorsten
                      Thanks for the reply instinct - The shot I was worried about got rendered in the end - not great at 3 hours a frame but it's done. Not really the most flexible thing for last minute changes but anyway...
