sRGB is a complex transform, which is only approximated by a gamma of 2.2 (or inverse of 0.4545).
It's however close enough to be nearly analogous: you'd be able to spot the differences if you flipped between images only in particular cases, and i'd wager never when the texture was inside the render, driving one or the other shader parameter.
