group vraylight multiplier?
  • #16
    Originally posted by flipside
    Originally posted by s0real
    yes, in this instance they all have the same multiplier.
    thanks for the tip! i hadn't used wire parameters before.
    How do you wire parameters?
    It's pretty easy, just select to objects, open the dialogue, browse two the parameter of each object that you want to wire, select the direction (with the arrows) and press "connect". Voila
    Eric Boer
    Dev
    • #17
      like this...
      Animation/Wire parameters/Parameter Wire Dialog...
      or you can select the object and go to wire parameters in transform on the quad menu, then link with the dashed line and choose the parameter you want to wire in the list.
      when the going gets weird, the weird turn pro - hunter s. thompson
      • #18
        Thanks!
