VrayMtlWrapper not working
  • VrayMtlWrapper not working
    Hi
    I recently upgradet from Vray 3 to 5, and now my old saved VrayMtlWrapper don't work. It usually gives me the renderet objects with shados casting down on the ground, but without the ground in the alpha image. Now it don't include the shadows anymore.
    What am I doing wrong?
    Could you send some screencaps of the MtlWrapper's settings? If the Matte and Shadows options are active it should work (to work in the alpha as well, activate Affect Alpha, and set its contribution to -1). If the issue persists, do simplify the scene and sent it (or attach it here) via the contact form so we can take a look. Address it to me in the subject and include a link to this thread in the message.
      Here is my settings. These this saved material vorked perfectly in Vray 3, but now I can't get it to work. I gave the plane the VrayMtlWrapper material, and usually I would get a opp map with only the man and his shadow. Now I only get the man...!
        The scene is sent to you Aleksandar.hadzhiev
          Thank you for the provided scene. It seems the Standard (Legacy) base material is causing the issue. Attach a VRayMtl instead and it should work fine.
