Vray Dome Light HDRI change height position
  • Vray Dome Light HDRI change height position
    Hello! English is not my first language sorry. I'm rendering an archviz scene using an HDRI for lightning (Dome Light) and another HDRI using Dome Light but just for reflections and background, this last image was taken with a drone at the exact balcony location and height, so for rendering i move all my scene to put the camera on 0,0,0 and its perfect aligned the real background with the scene, the problem comes if i try to render from another camera with another height position, the horizon still on the same position, my conclusion is that is locked to the camera selected to render, exist any posibility to change this? Or i have to take another drone photo at the location whith the other height i need. I had taken photos at the height of all balconys on my archviz scene, and everything was fine until my client request more balcony on other area, until now, i just change the hdri and move all the scene to 0,0,0 on the camera i need to render and fine. Thanks
    Not sure if I understood correctly. You're using drone-captured images projected on a Dome Light to correctly align your camera view to the real-life image, but using a second camera does not change the viewpoint? Are you certain you're rendering the correct camera? Could you share images illustrating the issue?
      Yes, for align camera with real-life image, i have several cameras (1, 2 for villa, i can render all the cameras of course, but the background is at the same height, independent that the camera are not (all are at diferents heights), is not a bug, i have made a lot ot experiments, it seems the horizon line the cameras always is fixed to the center of the background.
        Your maps are most likely Screen projected. If the images are captured as a 360 panorama, you would need to change the bitmap's mapping to Spherical.
