Ok - I've searched lots on here - also tried the Chaos help files (which are poor in this respect unless i've missed the relevant section) and i'm struggling with rendering fly through animations in latest Vray and Max.
I've read Lele saying stick everything to default and choose animation from the light cache - and simply render - BUT - this takes far too long to render even with a decent setup......
Is there any way to speed things up - I loved using the LC/IRR map precalculation 'fly through' workflow where we did the LC first (using the now removed fly through option) - then added the IR map using incremental with only every 10th frame or so required - I could have my fly through lighting solution rendered in minutes and it always worked beautifully - now i'm stuck with using the painstaking slow Brute Force solution and rendering the LC every frame?
Is there really NO way to quickly render the GI lighting solution for fly through (camera motion only) animation now with the latest version?
If there is a way - I would massively appreciate someone pointing me / linking me to it!
Thanks.
Thanks.
