Open Image Denoise (OIDN) 1.4
  • Open Image Denoise (OIDN) 1.4
    Any chance of updating the Open Image Denoise (OIDN) to release 1.4 ?
    The update has not yet been implemented in V-Ray, however, it will be. What is the purpose of your question, if I may ask?
      Well, when you see the quality of the v1.4 with pre-filtering (http://www.cgchannel.com/2021/05/int...e-denoise-1-4/) it looks quite good to keep the small texture details
      I actually *only* use the intel denoiser for all my still renderings, i find it looks the best compared to vray (sorry... ) and nvidia!
        We found our multi-frame (even the per-frame one, really.) was *miles* ahead of the Intel's one for detail retention, up to v 1.3.
        To be clear, we got precisely the results they use to show the better detail retention of v1.4: extreme smoothing of some (or all!) image areas.
        Would you be so kind to share some of the details and some of the results with me, perhaps via email, so i can check if i was doing something horribly wrong?
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          here twho images, one with intel, one with default vray denoiser
          look how vray blurs way too much the detail of the ground textures, espacially on the floor on the top of the image!
ID:	1115005Click image for larger version
            ah, and till with IRmap/LC on this one, BF/LC is in my opinion still way to noisy for more or less the same render times
              So, to be clear, those two are the same input passed through our denoiser at default values, andf the intel denoiser v 1.3?
              If they are, would you mind sharing the source image, with its render elements, towards my email?
              Lele
              Disclaimer:
                yes, all default value, i will send you a wetransfer of the archive right away
                  Thank you ever so much!
                  Lele
                  Disclaimer:
                    It's a great comparison if you use the Phoenix foam shader as an example. Intel gives amazing results. So finally I can render foam with vray
                    You can also compare how Intel cleans bokeh and motionblur on the same example. Vray gives bright squares almost always on bright spots which Intel cleans up amazingly clean.
                    I just can't seem to trust myself
                    So what chance does that leave, for anyone else?
                    CG Artist
                      Lele, did you had a chance to try out the scene i've sent you ? Anyway, if you need some beta tester for intel 1.4 denoiser, i'm in !
                        I didn't.
                        I replied with a thankyou, but hadn't checked the archive until now.
                        Are you denoising JPGs as a matter of workflow?
                        Lele
                        Disclaimer:
                          I mostly save to JPG, and no photoshop whatsover most of the time
                            Paul, what's what in your three images?
                            Lele
                            Disclaimer:
                            • #15
                              I'd need an EXR or VRImg, with the set of REs so to be able to do tests of my own.
                              Lele
                              Disclaimer:
