Vray triplanar with substance materials
  • Vray triplanar with substance materials
    Hi There,
    Is there a way to pass a substance material through one triplanar node?
    eg. the diffuse, normal maps etc. all pass through the same tri-planar on the way to the vray material node?
    Thanks in advance for any help in this regard.
    Kind Regards
    Kirado
    I don't think so, though I can add controller nodes to control each TriplanarMap's values.
      Hi Aleksandar,
      Thanks for the reply, I was reading through the forums and it sounds like the solution is to bake the texture channels.
      Would you know if there is a quick way of bringing in the the group of baked maps?
        If you have a lot of maps, maybe a MaxScript that loads each one in a VRayBitmap should be helpful.
          Hi, any suggestions on a good script to use?
