Distributed rendering server list (config file)
  • Distributed rendering server list (config file)
    Ok, I Give up. I know once a long time ago somewhere I found the file that contains all the distributed servers (that max writes to when you add/delete servers) so I wouldn't have to put them all in one at a time in max on a new install. Where is that text/config/ini file? I remember it was buried deep and I would forget where it was. I did.
    Thanks,
    -k
    Found it.
    C:\Program Files\Autodesk\3ds Max 20XX \en-US\plugcfg\vray_dr.cfg
    If your useUserProfiles=1 then it will be in the "c:\users\username\AppData\Local\Autodesk\3dsM ax\2 020 - 64bit\ENU\en-US\plugcfg" directory instead.
    https://forums.chaosgroup.com/forum/...le#post1040083
    -k
