Fully procedural material gradient inset help
  • Fully procedural material gradient inset help
    I'm trying to make a procedural map to control the hue of a forest pack, usually in the past I've used a mix of Vray's distance map and offset splines to create same effect, this takes a long time and is inconvenient for complex shapes. Ideally I'd like a to procedurally do this with a single, or combination of procedural maps. Below is an example of how this would look and how I've done it in the past with splines and Vray's distance map.
    Thanks!
    http://www.glass-canvas.co.uk
    I'm not entirely certain what's the desired effect based on that particular image. Could you elaborate a bit further? Maybe provide a simple example scene with the mentioned method.
      Hi Hermit,
      The goal of the map has a few uses for me, but the one I had in mind was a grayscale map that 'maps' itself from the outside in. if you've used the 'inside glow' in photoshop; essentially this. As an example for its use, this would allow me to create this effect, conforming to the shape of the geometry for something more complex then a simple rectangle:
Name:	b60b3f4b825c3ddf5b8a54c0b4f5cd93?auto=format%2Ccompress&w=1280&h=593&fit=crop&crop=faces%2Cedges.jpg
      If need be I can provide a scene file but I'm not sure how useful it would be.​
        mapped gradient ramp (https://youtu.be/kWfvOiRUN6s but mapped with VRayDistTex):
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          I see. I tried experimenting with some 3ds Max native procedural maps, however, the issue seems to be mapping the "gradient" to the specific shape. This indeed seems to work best with a Gradient Ramp mapped via a VRayDistanceTex. Another way perhaps is to vertex paint the surface itself, which would certainly provide more control, though it may be just as time-consuming.
            hermit.crab good point about Vertex Color. to make it easier you could drive it with soft selection of edge vertices through Data Channel:
Name:	Screenshot 2021-10-11 131339.jpg
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
              Thank you Piotrus and Hermit, this is exactly what I was looking for!
              Pinotrus would It be possible to see your material editor node set up, for future refrance?
                sure thing:
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
