Get Vray Light Dome texture
  • Get Vray Light Dome texture
    Hi, does anyone know the proper max script command to get the texture path ?
    if its a regular bitmap, and the dome light is selected, you can use:
    Code:
    $.texmap.filename
    otherwise if its a vrayhdri/vraybitmap and the dome is selected you can use:
    Code:
    $.texmap.HDRIMapName
    Kind Regards,
    Morne
      Thank You ! This worked for my needs
