V-Ray 5.2: Options in VFB save drop down
  • V-Ray 5.2: Options in VFB save drop down
    Hey guys,
    I am wondering what the little option cog-wheel is for in the VFB saving drop down. I'm guessing to find the color correction bake-in there, but I have no idea how to access the options. When I navigate the mouse over the cog-wheel icon and release the mouse button, nothing is happening.
    It's not obvious but you need to click on the little white triangle which'll make the dropdown menu stay open so you can click the option to save the adjustments
    EDIT: Actually it's just a long press on the icon itself that'll do it.
      Hey kosso_olli,
      As noted, a long press on the save button would do the trick for you.
      Alternatively, you can also access that setting via the VFB File > Save all image channels to separate files option.
      Nikoleta Garkova | chaos.com
        Hello,
        To click the button from there you'll need to press and hold the mouse button until the popup menu appears. Then you release the mouse button and then you can click on the cog-wheel button. That's some specific thing about the popup menu that appears from toolbar buttons. Alternatively you can just use the File menu.
        The options are saved per user so if you always bake the corrections - you'll need to use it only once.
        Yavor
        Yavor Rubenov
        V-Ray for 3ds Max developer
