Hello. I Have some questions, hope to get a reply.
1. Is it best practice to use LC in vantage or disable it ? If we disable it does it use only BF method ?
2. For final renders what shout be idle sample rate ? 100, 200, 400 etc ?
3. Do the settings in render panel only effect the display image which is rendered in viewport ? or does it effect the render high quality snapshot and sequence in tools menu when your doing the final rendering ?
4. I have 2x 3090 24GB RTX cards, it has nvidia nvlink attached.
a. should i enable SLI mode ?
b. if yes, then does it support doubling on ram, (in my case 48gb)
Thank You
Thank You
