Hi what do you mean by "dome camera"? Are you using VRayPhysicalCmaera in spherical mode? The VRay Toon works with all camera types. Could you explain a bit further what are you using?
Well this is strange.
I was using the VRayDomeCamera set to 180 degrees. It seems that VRayToon will only work up to 179.7 degrees.
Can you confirm this please?
I tested with 3ds max 2020 and V-Ray Next 3.2 (latest on our downloads page) in you scene and it does not work. However in a new scene the VRayToon works fine with VRayDomeCamera?
Are you using a nightly version of V-Ray Next?
Thanks.
I just tried it in a new scene but it did not work either.
My version of V-Ray is V-Ray Next update 3.3 (4.30.03 build 30952) installed from the file 'vray_adv_43003_max2020_x64.exe',
Hi this is a stable version from the 25th of August. With it indeed the toon is not working. I suggest that you install a different version and go from there.
