Script Callbacks Between Rendered Frames?
  • Script Callbacks Between Rendered Frames?
    Hi, I'm trying to execute a script between each frame when rendering a sequence, but the usual 3dsmax callbacks aren't working. I've tried
    Code:
    [B]callbacks.addScript #postRenderFrame[/B]
    and
    Code:
    [B]callbacks.addScript [/B][B]#preRenderFrame[/B]
    , but neither calls mid-sequence: only at the beginning or end of the entire sequence being rendered. Is there another way to approach this that's vray-specific?
    Code:
    fn myCallback = print "hello"
    callbacks.addScript #prerenderframe myCallback id:#myPRFCallback
    This prints out at each frame of a rendered sequence for me.
    #prerenderframe callbacks have certain limitations, what isn't working for you?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Ah, thanks for confirming that it should be working! I added a few more "print" calls to help debug, and discovered I was removing the callback prematurely.
      Edit: also discovered that currentTime.frame does not change between each frame, and always returns the first frame number of the sequence being rendered.
        That too works for me.
        Code:
        fn myCallback = print (currentTime.frame as string)
        This prints me out the float value for each rendered frame.
        Lele
        Disclaimer:
          Interesting. When I tried the following, all I ever got was "0000":
          Code:
          f = formattedPrint currentTime.frame format:"04d"
          print f
          Alternatively, when I just create my own variable and increment it, I get the desired output:
          Code:
          frameStart = 0;
          frameSkip = 10;
          function saveIRM =
              f = formattedPrint frameStart format:"04d"
              print f
              irmPath = "v:\\IRM\\irm"+f+".vrmap"
              vr=renderers.current
              vr.saveIrradianceMap(irmPath)
              frameStart = frameStart + frameSkip
          There's certainly some nuances of MaxScript that slip past me.
