VrayRendeTime RE - Can't see Pixel information Panel
  • VrayRendeTime RE - Can't see Pixel information Panel
    I'm trying to diagnose a render and wanted to read render time as pixel information, but can't seam to find it. Pixel Information panel doesn't show at all. When I click on pixel (in VrayRenderTime RE) nothing happens. Do I need to enable it somewhere?
    Max 2020, Vray 5.20.01.0001
    Hi are you using Progressive sampler? The VRayRenderTime works only in bucket mode.
    https://docs.chaos.com/display/VMAX/VRayRenderTime
    Vladimir Krastev | chaos.com
      Thanks Vladimir for your quick reply.
      I'm in bucket mode. When I RC on VFB nothing happens. Info panel doesn't show up. Any idea?
      z.
        Yes the new VFB displays the pixel information in a horizontal bar in the bottom-left corner
        Here is the docs article: https://docs.chaos.com/display/VMAX/...fer-VFBToolbar
          Vladimir,
          To illustrate above is the image from your help file
          When I right click on VrayRenderTime RE nothing happens. I can't open "Pixel Information" panel (in blue) and therefore can't see render time information (in red). I tested this with another co-workers and they have the same problem
          Thanks
          z.
            Hi this screengrab is for the earlier version of VFB. V-Ray 5.20.01 (as you stated in your first post) uses the new VFB and the pixel information is displayed in a different way - https://docs.chaos.com/display/VMAX/...fer-VFBToolbar
