OCIO -> Multimatte channels showing different shades - is this right?
  • OCIO -> Multimatte channels showing different shades - is this right?
    like this here. You can see slightly for example vertical lines in different red.
    Switching to sRGB made it looks like usual back again.
    Also I am wondering, how to save an OCIO preset in Framebuffer? I almost have to relocate it and do my dropdown choices by Hand.
    Setting the Path and preset there or in the Rendersettings (preferberally maybe: -> Redersettings -> Settings -> Color management
Name:	Screenshot 2022-05-04 153958.jpg
    These are the settings:
Name:	Screenshot 2022-05-06 150720.jpg
    and what about this "Recent"? I can never choose on recent ones, or the Pathhistory ( if it should be one) is remembering anything.
Name:	Screenshot 2022-05-06 150855.jpg
    thanks Guys!
    1. Not sure what's happening in the Multimatte. Could you strip down the scene and attach it here?
    2. No way to choose OCIO-specific presents separately at this point. You may use the global VFB2 preset system instead (would override other adjustments, though. You should load the preset prior). Also, you may use the OCIO environment variables to set defaults. It may serve as a good base.
    3. The Recent option displays the recent OCIO configuration files loaded, rather than specific settings. You can actually set a default in the config file itself, which may be used as a preset (though you need to copy the config files) through the Recent dropdown menu.
