which denoiser?
  • #16
    Originally posted by Muhammed_Hamed View Post
    Hi super gnu
    You can add multiple Denoiser elements, each in its separate channel. And compare in post
    the V-Ray denoiser is very good with animations, I usually use that + AI denoiser I mix them in post depending on the results I have.
    Hi Muhammed_Hamed . How can I accomplish this? i tried adding 3 Denoise RE and selected each of three denoise engines in each one and selected Render Elements Only.
    I rendered out a sequence in multichannel EXR.
    when I try to run it in Vdenoise i can see elements are missing and when trying Nvidia i get the error"Could not load vray_optix_denoiser, error [loadLibEx] 126: LoadLibrary failed (126): The specified module could not be found."​
Name:	Screenshot 2024-12-02 081150.png
ID:	1221653 Click image for larger version
Name:	Screenshot 2024-12-02 081208.png
ID:	1221654 Click image for larger version
Name:	Screenshot 2024-12-02 081424.png
    • #17
      Originally posted by Joelaff View Post
      Does the temporal denoising do something special other than:
      Code:
      For each pixel
      Get its world position
      Get the pixels with the same world position (+/- some epsilon) from previous and next frame
      Average those pixels
      If this average is within some threshold of the original pixels values use the average, otherwise do not change (or lerp)
      Maybe do that before running the denoiser itself.
      I’ve done similar before in the post, but never bothered incorporating the world positions. Seems reasonable.
      I remember a while ago I read on here (I think it was Lele that said it?) that rendering two frames will give you better results on frame 2, than if you just rendered a single frame. Not sure if it's worth the additional render time however...
