Light mix save
  • Light mix save
    I'd like to know if there is a way to render a shoot or a sequence and have the frame buffer save the file with a LightMix setup I've prepared earlier.
    At the moment I have a setup I like but I have to change and save each frame individually.
    Amir
    You can apply your lightmix to your scene. But normally if you render with the lightmix set up like you wanted, it should render the next frames with these applied. Alternatively you can use Pulze Scene Manager to load a VFB layer setup normally.
    A.
    www.digitaltwins.be
      Hi if you use the "Separate render channels" output dialog the LightMix effect is applied and saved in every frame.
      Vladimir Krastev | chaos.com
        I'm rendering a still animation with a window opening. that's ok.
        I am not familiar with "Pulze Scene Manager".
        do you know of other ways to go about it? something native from Chaos?
        thanks
          it seams like problem is about the Vray version. on one computer running vray 5.1 the issue occurs. on a second PC running vray 6 it works fine.
            Hi how are you saving your output, which dialog or the VFB?
