VRayAO renderpass background
  • VRayAO renderpass background
    I want to render a VRayAO render pass and composite on top of the RGB pass in the frame buffer.
    But the renderpass renders the background as black so that when I comp it on top it turns my background black (I've set a coloured background in the Environment dialog)
    The help says 'The background is calculated with unoccluded color by design. You can use compositing with the New V-Ray Frame Buffer (VFB)' Surely the 'unoccluded color' is white? but it renders black.
    So I can't use the AO pass to comp on anything if there is an empty background in the shot.
    Am I doing something wrong?
    I'm using VRay 5
    Garry Clarke
    Technical Illustrator
    www.garryclarke.com
    Ahh I think I've tracked it down - I'm using a VRaySphereFade and it gives the AO pass a black background outside of the sphere.
    Any workarounds?
    Garry Clarke
    www.garryclarke.com
      Maybe enable the "Affect alpha" of the SphereFade, so as to use it as a mask?
