Metal texture Help please!
  • Metal texture Help please!
    Hello, I have an image of a metal texture and I need to match it for a project. If anyone could give me a suggestion as to how to go about making this antique nickel, I would really appreciate it. I have watched tutorials on how to make the base nickel metal texture, but it needs those little irregular lines on it to "antique" it. Thank you for any assistance.
Name:	Antique Nickel.jpg
    You can try and adapt some texture from materials from Cosmos, or make yourself a procedural one, by stretching a noise (either in UV space, or in 3d space.) and sharpening its cutoff.
    The same texture could then be used to drive anisotropy rotation/amount, specular roughness, and if you have to get up close, also a smidgen of bump (via vrayColor2Bump texture.).
    You could also use the texture as mask to characterise the shader further (i.e. color and such.).
    You'll probably need a bit more than the original Max Noise, and if that is the case you may find stuff like SigerNoise useful (not an endorsement.).
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Thank you for the response, Lele. I'm struggling a bit to keep up with you, sorry. How do you sharpen the noise's cutoff? Is noise the same as a bump texture?
        I've attached you a max file.
        Notice i left bump off, while it's set up properly, because it's not needed, i think.
        Replace the HDR image in the dome light with one you have, or one from Cosmos (i am not sure i have the rights for the one i used to go around.).
        Not that it being reflective, most of its look will come from the choice of HDR probe, and/or lighting.
        Lele
        Disclaimer:
          Lele, you are awesome! Thank you so very much.
