Vray Decals in version 5
  • Vray Decals in version 5
    Are the decals not supported in vrscene exporter or vantage.
    They are, currently, not supported in Vantage (internal bug-tracker id: LAV-1047). I'll boost the issue's priority.
      Ok Thanks. So they dont work in the vrscene exporter either? I was having problems with DR picking up a huge file so I thought I could just do a vrscene export and bring it back into 3ds max. It worked like a charm except for some reason the cameras lights decals and a few other textures did not come back, when I brought the vrscene back into max
        The other material type that did not show was a VRAY Blend material
          Yes, in V-Ray 5, decals are not rendered when imported in a VRayScene node. This is fixed in V-Ray 6.
            Great we are trying to upgrade if we can get our corporate IT to cooperate.
            Are VRAY Blend materials supposed to work in VRscene in version 5?VRscene version
              They should work, so maybe it's something specific. Could you apply the shader to a simple object, export, import in VRayScene, and render? If the issue persists, attach (or send) the scene so we can take a look.
