Does VrayToon atmosphere effect require lights?
  • Does VrayToon atmosphere effect require lights?
    for I test the scene like this with VRayToon atmosphere effect
    Click image for larger version  Name:	toon1.jpg Views:	0 Size:	14.1 KB ID:	1160143
    the VRayToon render element , some alias appeared in shadow area
    Click image for larger version  Name:	toon2.jpg Views:	0 Size:	18.7 KB ID:	1160144
    back light added , alias are gone
    Click image for larger version  Name:	toon3.jpg Views:	0 Size:	19.6 KB ID:	1160145
    so Does VrayToon atmosphere effect require lights?
    and last I changed vrayToon line color to red , and all lights deleted , it works well, I got some confused...
    ( the red line rendered image and VrayToon render element , they are good )
    Click image for larger version  Name:	toon4.jpg Views:	0 Size:	18.2 KB ID:	1160146 Click image for larger version
    Hi I tried to create and test a scene that is similar to yours but mine looks ok.
    http://ftp.chaosgroup.com/support/sc...0_10-09-53.jpg
    http://ftp.chaosgroup.com/support/sc...0_10-09-14.jpg
    Vladimir Krastev | chaos.com
      The gray line is good ,
      only black color , in complete darkness , please test it
      render result has no problem , but Render Element got alias in total dark area
        Yes you are right. Let me investigate a bit further and I will get back to the thread.
          Thanks,
          And then I tried to delete all lights , edges around object are smooth , edges inside object are noised ...(in render element) , maybe its not depend light..
            Hi you could try raising the min subdivs parameter in the image sampler settings.
            Start with a value of 2 and if the result is still not good enough, go higher.
              It works! 8 min subdivs is fine for my scene, thank you
