No Texture Bake w VrayDisplacement mod?
  • No Texture Bake w VrayDisplacement mod?
    What should I do to get “render to texture” to work with an object that has VrayDisplace Mod? I don’t need a bunch of different channels, just the main image. I tried it with Vray Frame buffer(realRGB, Mateiral Color) and with out, but either way all I get is black images. If I do a regular render, then the VRdisplaceMod works fine.
    Thanks much for the help
    Baking an object with a VRayDisplacementMod will not work properly. You can use the Displace modifier in 3dsmax instead.
