ACEScg
  • ACEScg
    What is it, and why should I care? I am trying a plugin that converts my scene to ACEScg, which promises a more accurate color. I must say, I think my colors are more accurate. However, I am seeing much more noise in my images. Any tips?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi the amount of noise in you image is not directly related to ACEScg.
    Can you give us an example, a comparison of the two images?
    Vladimir Krastev | chaos.com
      Are you using AColorManager for switching? How is it holding up with a scene with lots of materials from different sources? And Forest Pack and all?
      A.
      www.digitaltwins.be
        Yes, I am using AvizStudio's AColorManager. It is fast, even with large scenes, and with Forest Pack. It screws with my HDRI, and it looks like GPU doesn't support it, but other than that, it seems to work,
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Maybe it isn't ACESsg causing the noise.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            if your images go from VRay to PS to client - just don't bother with ACES.
            some old tests: https://youtu.be/XJlNVbmKtA8
            Marcin Piotrowski
            youtube
            CGI OCIO config 04
              what is a use case for using it?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                it’s a colour management system. consistency between aplications, cameras, displays etc.
                one part of it are colorspaces much wider than srgb. it can futureproof the content for when more capable displays and projectors become available. you can also use it (one of aces colorspaces, acescg) to do all the calculations within VRay. it will handle high saturation scenarios better - but if you haven’t noticed difference in that regard between VRay and Corona it won’t blow your mind.
                and try the little script Lele posted some time ago - color space swapper or something along those lines. much simpler solution. all you really need to do is to tell every VRayBitmap what colorspace it contains. its all in the docs.
                Marcin Piotrowski
                youtube
                CGI OCIO config 04
                  I can tell the difference, and I used it on my past two projects; both have much richer colors than I normally get. I'll look up the script you mentioned.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    acescg would actually produce less saturated colours in VRay when compared to srgb. or rather oversaturated colours in srgb mode would look more natural when calculations are done in acescg.
                    Marcin Piotrowski
                    youtube
                    CGI OCIO config 04
                      and where did he post it?
                      thanks for relinking it over here! =)
                        I found that a script I already have does it. I'll post that shortly.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          google harder !
                          Marcin Piotrowski
                          youtube
                          CGI OCIO config 04
                            Built in to V-RayMax Converter pro
Name:	Color Space.jpg
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              i seem to spend most of my time in that tool these days...max or vray needs a rule system like maya where you can specify texture naming and their corresponding colorspace info.
                              e: info@adriandenne.com
                              w: www.adriandenne.com
