documentation update?
  • documentation update?
    https://docs.chaos.com/display/VMAX/V-Ray+Frame+Buffer
    at the bottom is this bullet point:
    • Even when the V-Ray VFB is enabled, the 3ds Max VFB is still created and thus takes additional memory. To reduce that memory, uncheck the Get resolution from Max option, set the 3ds Мax resolution to a low value like 100 x 100, and then select your actual output resolution in the V-Ray tab > Frame buffer options in the Render Setup window.
    ​i am using GPU rendering and do not see the option for "Get resolution from Max" , or "actual output resolution in the V-Ray tab > Frame buffer options"
    is that old documentation?
    thanks,
    The options are not yet implemented in V-Ray GPU, so the docs refers to V-Ray CPU only.
