batch render to VRIMG files and PNG channels
  • batch render to VRIMG files and PNG channels
    Hi, I woiuld like to send to the DR server jobs and have them saved as PNG ( for all channels ) but also save the vrimg file along. Is this possible ?
    It should well be, yes.
    Use the raw file output for the vrimg (but why not save and EXR? you just need to pick the extension in the file save dialog.), and the split channel output for the PNGs.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Hi you can enable both "V-Ray raw image file" and "Separate render channels"
      Vladimir Krastev | chaos.com
        OK this works fine except for the effects_channell which is not saved somehow. Any idea why ?
          Ah, i see the effects is saved as the normal file name. I was also wondering if i can batch render this ? Do I need backburner for that ?
            You can also use the max batch render capabilities, without need for BB, if you plan on local rendering.
            Lele
            Disclaimer:
