V-Ray Bitmap to VrayBirmap Converter
  • V-Ray Bitmap to VrayBirmap Converter
    When using this tool, image maps converts Color space transfer function to Inverse gamma and RGB color space parameters to Default. Working in ACES color space I need to then go in and change each image maps Color space transfer function and RGB color space individually. Is there a script that gives me control over all of this so I don't have to do each one manually? Renaming the image files is not an option in our process.
    Hi, thanks for posting. The V-Ray Bitmap to VrayBirmap Converter uses the VRayBitmap's default settings. Should we discuss them instead?
    Vladimir Krastev | chaos.com
      Sure, the materials with the image maps I'm converting are very old. So is there a better way to automate the "default settings" to what I need to change them to?
        Hi I don't see any other option but using a script. I will try to collect more info and get back to the thread.
          Does this do what you need? https://www.scriptspot.com/3ds-max/s...-converter-pro
          A.
          www.digitaltwins.be
