Find objects with missing maps
  • Find objects with missing maps
    Is there a way to quickly select objects in a scene that have materials that are missing .tx maps? I found a thread on the Max forum that pointed out the Bitmap/Photometric Path Editor in Utilities, but that doesn't seem to list .tx files from the VRay library, which is apparently what I'm missing. Thanks.
    - Geoff
    Tried project manager? It has a free trial at least.
    https://3d-kstudio.com/product/project-manager/
      Meaning the .tx file isn't found on disk?
      If that's the case, this snippet should help:
      Code:
      clearSelection()
      for m in getclassinstances vraybitmap do
      if not doesfileexist (mapPaths.getFullFilePath m.hdrimapname) do selectmore (refs.dependentnodes m)
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Also with relink bitmaps script (https://colinsenner.com/relink-bitmaps/) if you double click a map that is missing it will select the objects that have this map missing.
        A.
        www.digitaltwins.be
          Soon enough, we won't be needed at all anymore.
          The attached script works for the OP's original request.
          Lele
          Disclaimer:
            My god...is this OpenAI? You had to do a lot of correcting though and in your case it would have been simpler to write it yourself, as a non-coder I wouldn't know where to steer it. But soon all these corrections from coders will let this AI learn a lot, but without the forgetting part, that we struggle with, absolutely crazy.
            A.
            www.digitaltwins.be
              It is, yes.
              Indeed, for now it's much harder (as in amount of verbiage), and quite "dirty" (as in, i can't let it infer, i need to quote him EDIT: it* directly methods and commands.) to have it achieve anything.
              Notice my naive solution above takes maybe two minutes to write, including fetching stuff from the docs.
              Alas, it's done stuff that's positively nuts, and that i surely couldn't tell from a human.
              For example, our colleague Oleksiy mentioned this bit of trivia:
              Alan Turing paper on Computing and Artificial Intelligence in which he proposes a possible test of a computer's intelligence by posing questions which the computer answers.
              He proposes the following question and answer as an example:
              Q: Please write me a sonnet on the subject of the Forth Bridge.
              A: Count me out on this one. I never could write poetry.
              And of course there was only one thing to be done.
              Click image for larger version  Name:	image.png Views:	0 Size:	85.7 KB ID:	1167178
              I was blown away, it has done an AABB instead, but nigh perfect and with some meaning.
              But then came the real surprise.
              Click image for larger version  Name:	image.png Views:	0 Size:	21.7 KB ID:	1167179
              Lele
              Disclaimer:
                This is....absolutely fantastic...and also terrifying at the same time. I'm fiddling with MidJourney once in a while and I can't just get over the fact that these AIs spit out inspiring images, that are seemingly correct in a lot ways. But coding or writing poems as well...Mind blowing.
                Is this a paying version of openAI or just the beta of ChatGPT.
                I think AI is advancing much faster than anticipated. I wonder where our jobs will be in 5-10 years time.
                A.
                www.digitaltwins.be
                  The latter.
                  https://chat.openai.com/chat
                  Lele
                  Disclaimer:
                    Totally OT for here, but there are a number of interesting considerations to be made. we should start a thread.
                    Lele
                    Disclaimer:
