Transparent Texture or Object?
  • Transparent Texture or Object?
    I am looking for the best/most efficient way to achieve a decent look for a transparent object. I've been simply adjusting the Visibility of the object (under object properties); however, I don't find the quality the best and render times are HUGE. What I'm trying to achieve is a good way to show the interior electrical chase through this object. See below:
    Should I play with a transparent material? If so any pointers on that front? (I've never worked with a transparent material before)
Name:	Figure 13-2_01_Faded.png
    Hi, thanks for posting. Using a transparent VRayMtl is the right way to go in my opinion. We even have a suitable built-in material pre-set to the VRayMtl - Glass (frosted)
    Here it is:
    I edited the setting a bit to get this:
    Depending on your lighting, desired effect and thickness of the refractive object you may need to tweak the settings.
    Here is the help page for VRayMtl - https://docs.chaos.com/display/VMAX/VRayMtl
    Vladimir Krastev | chaos.com
