3dsmax Normal Bump Map gone when vray active
  • 3dsmax Normal Bump Map gone when vray active
    Hey folk. So I just noticed if you have vray set as your renderer, the max "Normal Bump" map is gone from the available list of maps. Of course I can always use the vray normal bump map which apparently is more compatible with various vray object types in the manual, but I just wanted to check that the regular max Normal Bump map is still fully compatible on regular geometry when rendered in vray?
    - Neil
    HI, thanks for posting. What version of V-Ray and 3ds Max are you suing? Why would you want to use Normal Bump? Have you tried VRayNormalBump and why not use it instead?
    Vladimir Krastev | chaos.com
      The regular Normal Bump map should be avoided as much as possible - it causes issues ranging from slowing down the rendering to crashes.
      Yavor Rubenov
      V-Ray for 3ds Max developer
        Vladimir: max 2022, vray 6. I'm doing a lot of importing and exporting of fbx files between apps, and the fbx format knows nothing of vray so it's creating a lot of Normal Bump maps on import, and needs Normal Bump on export.
        Yavor: Ick, that sucks. Guess I'll have to convert them to vraynormalbump when rendering in vray, then convert them back to export.
        - Neil
          Originally posted by soulburn3d View Post
          but I just wanted to check that the regular max Normal Bump map is still fully compatible on regular geometry when rendered in vray?l
          It is not, V-Ray even prints a warning about this. The standard 3dsMax normal map is known to cause considerable delays when working with IPR.
            Thanks for the info Oliver! Wish that fbx understood vray maps
            - Neil
              Yeah, that would be fantastic. Would make our lives so much easier!
